Wireguard client (BerylAX) is not connecting to server (BerylAX)
Hi all, I'm attempting to use a BerylAX as a Wireguard server and another BerylAX as Wireguard client. Doing this, I will be able to always have my home IP anywhere.
However, when I try to connect clie it gets stuck in "The client is starting, please wait…"
These are the logs I get on repeat:
Sun Jul 21 19:17:30 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Jul 21 19:19:17 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sun Jul 21 19:19:17 2024 daemon.notice netifd: Interface 'wgclient' is now down
Sun Jul 21 19:19:17 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Jul 21 19:19:17 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
These logs show on repeat.
These are the steps I followed:
  1. Connect BerylAX 1 to my home router via ethernet cable. Internet works.
  2. Turned on dynamic DNS
  3. Start WireGuard Server
  4. Go to my home router config 192.168.1.1 -> firewall -> port forwarding. Here I have multiple fields:
  • Protocol: UDP
  • Wan Host IP Address: 0.0.0.0
  • LAN Host: the "Ethernet" IP Address from the BerylAX Dashboard
  • WAN Port: 51820
  • LAN Host Port: 51820
  1. Added a new user to the WireGuard Server. Copied the config (with the endpoint changed to the DNS+port)
  2. Connect BerylAX 2 to my phone internet (making sure it only has data enabled, no wifi). Internet works
  3. Go to WireGuard Client and paste the config of the user created in the BerylAX server
  4. The VPN gets stuck in connecting...
Thanks in advance for your help!
Please have a look into How to troubleshoot WireGuard
I guess you are using the default network on both Beryl, which won't work.
On the BerylAX client I went to network -> LAN and changed it to 192.168.12.1.
The BerylAX server is still 192.168.8.1.
My home router is 192.168.1.1
It still doesn't work. Thanks for your help!
Are you sure that your server has a public reachable IPv4 address?
No CGNAT and no Spectrum as ISP?
According to this guide How to check if you have a public IP - GL.iNet Router Docs 4
the IP address in the "Ethernet" section should be the same as the IP address when I access a website that tells me my IP right?
Then, it seems I don't have it cause they don't match. Would I need to "enable" my main router to have public IP address so the connection between client and server VPN work?
When I check my IP in https://whatismyipaddress.com/ for both the main router and the server Wireguard, both are the same and start with 209
I am having the same issue. It's not connecting to the WG vpn
The question is if your ISP allows incoming connections. What ISP do you use?
It seems that you don't have a public IP so your wireguard server is not working.
Exactly, I found out that my ISP uses CGNAT.
I think I have three options here:
  • Buy static public IP from ISP
  • Use IPv6? What are pros and cons here?
  • Use Tailscale
Is this correct? Which option would you recommend? Thanks
Currently you can try Tailscale.
Dealing with ISP needs extra money and time, and not promising if it surely work.
I called my ISP and asked for a static IPv4 and now it works!
I'll try it again later on a different Wifi (I used my phone hotspot) and set this thread as solved if it works
Wow. So easy for you.
