I’m trying to setup a wireguard client connection from my GL-MT1300 to my wireguard-server at the office. I’ve used the online documentation to create the client connection: WireGuard Client - GL.iNet Docs
After creating the configuration and connecting the wireguard vpn through the gl-inet web interface i can’t seem to get traffic to pass through the tunnel.
Connection diagram1: wg-server <-> internet <-> gl-inet
My wireguard subnet is 10.11.12.0/24 where the server has .1/24 and the gl-inet has .2/32
I’m trying to ping 10.11.12.1 from the gl-inet device.
One strange thing i noticed that is when i do a traceroute from the gl-inet to 10.11.12.1 it seems to take the default gateway (internet) as opposed to the tunnel. Tcpdump on the server confirms no packets are received on tunnel and ethernet interface when i ping from the gl-inet.
To debug a little further i took the configuration from the gl-inet (wg showconf wg0) and copied it to a windows pc with wireguard behind the gl-inet
Connection diagram2: wg-server <-> internet <-> gl-inet <-nat-> test-windows-pc
When trying to establish the connection from the windows pc everything works as expected.
Ping to 10.11.12.1 works and traceroute shows a path through the tunnel on the windows pc.
I’m running out of ideas to test, and tbh i don’t see why diagram2 works and diagram1 does not.
So far i think it rules out a server-issue and a wireguard-client-config issue.
I tried lowering MTU to 1400 just for testing and that made no difference.
Anyone with a good hint ? ![]()
Cheers,
Zyx
