Wireguard client doesn't work on GL-MT2500A
I’m using 2 GL-MT2500A routers, the first one is my wireguard server and the second one is my wireguard client. Everything worked fine during a month. 3 days ago the wireguard client stopped to connect and show this error:
Sat Dec 24 19:43:12 2022 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Sat Dec 24 19:43:12 2022 daemon.err tailscaled[6499]: 2022/12/24 18:43:12 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth0 ifs={br-lan:[192.168.8.1/24] eth0:[10.0.3.150/24] wgclient:down} v4=true v6=false}
Sat Dec 24 19:43:12 2022 daemon.err tailscaled[6499]: 2022/12/24 18:43:12 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth0 ifs={br-lan:[192.168.8.1/24] eth0:[10.0.3.150/24] wgclient:[172.16.0.2/24]} v4=true v6=false}
Sat Dec 24 19:43:17 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Dec 24 19:43:23 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Dec 24 19:43:28 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Dec 24 19:43:33 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Dec 24 19:43:38 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Dec 24 19:43:44 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
The firmware version on the wireguard server side is 4.1.1 and I was using the same firmware on the client side. I tried to upgrade the firmware on the client side with 4.2.0 version but it didn’t solve the issue.
This the wireguard configuration:
[Interface]
Address = 172.16.0.2/24
ListenPort = 53990
PrivateKey = PRIVATE_KEY
DNS = 64.6.64.6
MTU = 1420
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = ******.glddns.com:51820
PersistentKeepalive = 25
PublicKey = PUBLIC_KEY
Can anyone help me?
Wg port 51820 is not reachable for some reason, need to do some network diagnostic, I just sent you a Private message.
Hi hansome,
the wg server was shutdown but now is power on again.
Hi Giuseppe, is it able to connect wg server after power on?
No, there is always the same error.
Mon Dec 26 17:42:02 2022 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Dec 26 17:42:02 2022 daemon.err tailscaled[6499]: 2022/12/26 16:42:02 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth0 ifs={br-lan:[192.168.8.1/24] eth0:[10.0.3.150/24] wgclient:down} v4=true v6=false}
Mon Dec 26 17:42:02 2022 daemon.err tailscaled[6499]: 2022/12/26 16:42:02 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth0 ifs={br-lan:[192.168.8.1/24] eth0:[10.0.3.150/24] wgclient:[172.16.0.2/24]} v4=true v6=false}
Mon Dec 26 17:42:07 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Mon Dec 26 17:42:13 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
I rebooted also the modem in the wg server location.
Tailscale affected Wireguard?
Sorry forget to sync status of this issue, @alzhao @yuxin.zou
After remote debug with giuseppefior3, we found the wg server side gateway port forwarding is not working for UDP, verified by set up a port forward from 51888 to port 53, and doing a DNS lookup like:
dig google.com @xxxx.glddns.com  -p 51888
giuseppefior3 said in his last email.
I found the source of the problem. The ISP blocked incoming UDP traffic on the modem.
I changed the Internet gateway on the wg server GL-MT2500 and now I can establish the VPN from the wg client.
I’ll try to contact my ISP customer care to solve this issue.
Please info us if any updates, thank you @giuseppefior3
