Using a pair of GL-SFT1200
One (4 in the chart) is used as WireGuard Server This shows no issue
The second one (8 in the chart) is used as WireGuard Client and is unable to startup the client.
The internet connection when connecting as WiFi repeater is absent too
Notice that I tried both DNNS and IP but the outcome is unchanged and still problematic
The log is as follows:
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Zone 'wan'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Zone 'guest'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Zone 'wgclient'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Set tcp_ecn to off
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Set tcp_syncookies to on
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Set tcp_window_scaling to on
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Running script '/etc/firewall.nat6'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Running script '/etc/firewall.vpn_server_policy.sh'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Running script '/var/etc/gls2s.include'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): ! Skipping due to path error: No such file or directory
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): * Running script '/usr/bin/gl_block.sh'
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): Failed to parse json data: unexpected character
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): uci: Entry not found
Thu Jun 13 17:32:38 2024 daemon.notice netifd: wgclient (10597): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Thu Jun 13 17:32:39 2024 daemon.notice netifd: Interface 'wgclient' is now down
Thu Jun 13 17:32:39 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Thu Jun 13 17:32:39 2024 daemon.notice netifd: wgclient (10753): Name does not resolve: `examplednns.com:xxxx' NOTE THIS IS INTENTIONALLY CENSORED IN THIS POST
Thu Jun 13 17:32:39 2024 daemon.notice netifd: wgclient (10753): Configuration parsing error
Thu Jun 13 17:32:40 2024 user.notice relay: Reloading relay due to ifup-failed of wgclient ()
Could you kindly provide assistance?
The setup is as follows just for the sake of testing out everything.
If you use WireGuard and the connection fails, it's pretty normal that internet does not work.
So for me those issues are connected. Let me send you to How to troubleshoot WireGuard so you can check the most common issues.
The connection fails as WiFi repeater BEFORE attempting the WireGuard connection...
Thus the issue lies in the glinet unit itself and it's WiFi connection ability
Hence the suggested guide will not help (furthermore it is way to generic)
Further tested both of the units. (GLSFT1200 8 and GLSFT1200 4)
Switched off the VPN Server and tried both the units ex novo in the following ways:
A- Repeater mode connected to the Modem/Router
B- Repeater mode connected to my phone in hotspot mode
In both cases and for BOTH the units repeater mode resulted in NO connection to the internet. (at no time during this test the units where both on at the same time to avoid interference)
I am concluding that the WiFi repeater mode is flawed in both the units, with high probability in the model itself.
I am left no other option than to return both the units, and sadly with a bad review.
No support was provided and the units do not do what they should
