Hello all,
I just got a GL-MT3000 “Beryl AX” device.
i been using GliNet mini routers for over 7 years now with the [GL-AR150]
So long story shorth, I’m getting the same issue others were getting with the GL-1800 Slate
Wireguard just wont connect as a client to the server, I have 3 other older GliNet devices that work and connect without issues, so this has to be an issue on the firmware.
I tried the GR firmware and then the Beta 4.2.0 still same issue with Wireguard client
Same exact error code as this thread:
I’ve been following this thread for a few weeks hoping to find a solution. I also have the REKEY TIMEOUT issue. Only using mullvad.
New Slate AX 1800
Tried multiple firmwares including the latest 4.2 beta 2.
-Previous versions didn’t let me pull a mullvad config at all when putting in my account number.
-4.2 allows me to pull the mullvad account from the settings page, but still have a REKEY TIMEOUT when trying to connect.
-OpenVPN works
Using the router at home, not 4G/5G
Not using IPV6
No…
USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
using the berylAX as a repeater mode for testing purposes connecting to a hotspot.
Please can we fix it WG client for the new BerylAX ?
forgot to add
Sat Jan 21 20:37:34 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Jan 21 20:37:42 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 21 20:37:48 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
alzhao
January 22, 2023, 2:50am
#3
REKEY TIMEOUT is the only error so it means nothing. Can I have a remote check using anydesk teamviewer? Pm me pls.
