My firmware is 4.4.6
Here are the logs when I connect to the wireguard server:
Wed Jan 17 12:38:47 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Wed Jan 17 12:38:53 2024 daemon.notice netifd: Network device ‘wgclient’ link is up
Wed Jan 17 12:38:53 2024 daemon.notice netifd: Interface ‘wgclient’ is now up
Wed Jan 17 12:38:53 2024 user.notice mwan3[12400]: Execute ifup event on interface wgclient (wgclient)
Wed Jan 17 12:38:53 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ CONFIG_mac_mac= HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_7544 group_511 group_9829 group_1187 peer_7766 peer_3044 CONFIG_cfg030f15_ports=
Wed Jan 17 12:38:53 2024 user.notice mwan3[12400]: Starting tracker on interface wgclient (wgclient)
Wed Jan 17 12:38:56 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Here are the outputs of the commands you indicated:
root@GL-MT3000:~# ip route
0.0.0.0/1 dev wgclient scope link
default via 172.20.10.1 dev eth2 proto static src 172.20.10.10 metric 30
128.0.0.0/1 dev wgclient scope link
172.20.10.0/28 dev eth2 proto static scope link metric 30
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
root@GL-MT3000:~#
root@GL-MT3000:~# wg
interface: wgclient
public key: KM0000000005Cjc8uq3ktndM8Rl+XGJybt000000000=
private key: (hidden)
listening port: 55787
fwmark: 0x80000
peer: eJ5FMnmO+000000000BqcLkbFobciqkyIX000000000=
endpoint: my-public-ip:51921
allowed ips: 10.8.0.0/24, 192.168.8.0/24
latest handshake: 1 minute, 25 seconds ago
transfer: 23.25 KiB received, 308 B sent
persistent keepalive: every 25 seconds
The client config is this:
[Interface]
Address = 10.8.0.2/24
PrivateKey = <private_key>
DNS = 8.8.8.8
MTU = 1380
[Peer]
AllowedIPs = 10.8.0.0/24, 192.168.8.0/24
Endpoint = my-host-name:51921
PersistentKeepalive = 25
PublicKey = eJ5FMnmO+000000000BqcLkbFobciqkyIX000000000=
And here are some tests done from a computer directly connected to the router while VPN is on:
alex@Alexs-MacBook-Pro ~ % ifconfig | grep 192.168.8
inet 192.168.8.141 netmask 0xffffff00 broadcast 192.168.8.255
I can easily ping the router:
alex@Alexs-MacBook-Pro ~ % ping 192.168.8.1
PING 192.168.8.1 (192.168.8.1): 56 data bytes
64 bytes from 192.168.8.1: icmp_seq=0 ttl=64 time=31.773 ms
64 bytes from 192.168.8.1: icmp_seq=1 ttl=64 time=4.930 ms
^C
— 192.168.8.1 ping statistics —
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 4.930/18.352/31.773/13.421 ms
I can ping the wireguard interface on the router:
alex@Alexs-MacBook-Pro ~ % ping 10.8.0.2
PING 10.8.0.2 (10.8.0.2): 56 data bytes
64 bytes from 10.8.0.2: icmp_seq=0 ttl=64 time=94.372 ms
64 bytes from 10.8.0.2: icmp_seq=1 ttl=64 time=97.923 ms
^C
— 10.8.0.2 ping statistics —
round-trip min/avg/max/stddev = 94.372/96.148/97.923/1.775 ms
I can ping the wireguard interface on the server:
alex@Alexs-MacBook-Pro ~ % ping 10.8.0.1
PING 10.8.0.1 (10.8.0.1): 56 data bytes
64 bytes from 10.8.0.1: icmp_seq=0 ttl=63 time=48.012 ms
64 bytes from 10.8.0.1: icmp_seq=1 ttl=63 time=54.174 ms
^C
— 10.8.0.1 ping statistics —
round-trip min/avg/max/stddev = 48.012/51.093/54.174/3.081 ms
alex@Alexs-MacBook-Pro ~ % ping 192.168.1.1
But I cannot ping anything beyond that … and I cannot see any packet coming to the server.
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
^C
— 192.168.1.1 ping statistics —
4 packets transmitted, 0 packets received, 100.0% packet loss
alex@Alexs-MacBook-Pro ~ % ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
92 bytes from console.gl-inet.com (192.168.8.1): Destination Host Unreachable
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 5400 c349 0 0000 3f 01 9e46 192.168.8.141 8.8.8.8
^C
— 8.8.8.8 ping statistics —
3 packets transmitted, 0 packets received, 100.0% packet loss
