I’m trying to route all my traffic through wireguard and failing. I have tested the configuration in other devices and it works perfectly. When I click connect on the GUI it actually connects to the server and creates the routing rules but nothing else happens. No traffic goes anywhere.
My firmware version is 3.025.
root@MT300N-V2:~# wg show
Warning: one or more unrecognized netlink attributes
interface: wg0
public key: [key]
private key: (hidden)
listening port: 55176
peer: [key]
preshared key: (hidden)
endpoint: [ip]:54321
allowed ips: 0.0.0.0/0
transfer: 0 B received, 296 B sent
persistent keepalive: every 25 seconds
root@MT300N-V2:~# ip r
0.0.0.0/1 dev wg0 scope link
default via 172.29.4.150 dev apcli0 proto static src 172.29.4.149 metric 20
[ip] via 172.29.4.150 dev apcli0
128.0.0.0/1 dev wg0 scope link
172.29.4.148/30 dev apcli0 proto static scope link metric 20
192.168.8.0/24 dev br-lan proto kernel scope link src 192.168.8.1
What I found very unfortunate with wireguard, is that it does not really give you an indication if the connection was established. What I have found as an indicator, that it is not connected if there are no bytes received.
Any “established” connection I had, had at least a few bytes received even if there was no traffic passing through.
I know this doesn’t really help, but maybe you could first start to find out, why connection is not really established.
Are the VPN policies active?
For me it worked best setting the IP of the local network outside the router as only “do not use” rule (If the router is connected directly to the internet the set “use only for” without setting any IP).
And I would have DNS set to 1.1.1.1 or 8.8.8.8 for testing until it runs and then take it from there.
I’m connected to a public hotspot with captive portal. It disconnects me every hour so I wrote a script to reconnect. The VPN policies are set so I can still access this portal with my script.
And the wireguard settings are functioning within that same public hotspot with another device (as a lot of public hotspots limit the open ports, which could block the tunnel)?
You were correct. It was a connection problem.
I had written the wrong Preshared Key
Since for some reason I could’n import the file I was copypasting from another file and pasted the wrong key. Did not notice till today.
Now it’s wrorking.
It is anyways annoying that I don’t have access to any logs so it’s really difficult to debug when there’s a problem.
Thank you for your help.
