Hi everyone, I have 2 GL-A1300 routers. One for travelling and taking with me. The other one is connected via Ethernet cable to my ISP router. What I am trying to do is set up a wireguard VPN between both routers so that I can use my home ISP IP address to work while using the travel router.
I had previously set this up and it was 100% working as I frequently checked my IP address and it was showing my home IP.
I recently updated the Firmware on bot routers and now it seems like my Wireguard Client does not start up anymore, I just get the message “The client is starting, please wait …”. I have forwarded the UDP port 51820 on my ISP router. The Wireguard Server is up and running.
Last message in the log is: Reloading firewall due to ifdown of wgclient ()
Can anyone help me? I dont know what to do now.
admon
February 7, 2024, 3:21pm
2
Could be this issue maybe:
A package is missed while we switch mwan3 to kmwan:
opkg update
opkg install iptables-mod-conntrack-extra
/etc/init.d/firewall restart
Execute those commands on the WG server router.
Please export the full log of wireguard client. It doesn’t look like the same case as Access LAN services through real IP with active VPN client - #21 by hansome
How do I do that? I am a bit of a novice when it comes to these things. Where can I execute such commands?
Here is the log when I try to boot up Wireguard Client:
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Rule 'process_mark'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Rule 'safe_mode_mark'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Rule 'safe_mode_mark_save'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): Warning: fw3_ipt_rule_append(): Can't find target 'CONNMARK'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Zone 'lan'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Zone 'wan'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Zone 'guest'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Set tcp_ecn to off
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Set tcp_syncookies to on
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Set tcp_window_scaling to on
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Running script '/etc/firewall.nat6'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Running script '/etc/firewall.vpn_server_policy.sh'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Running script '/var/etc/gls2s.include'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): ! Skipping due to path error: No such file or directory
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): * Running script '/usr/bin/gl_block.sh'
Thu Feb 8 11:32:21 2024 daemon.notice netifd: wgclient (26876): uci: Entry not found
Thu Feb 8 11:32:22 2024 daemon.notice netifd: Interface 'wgclient' is now down
Thu Feb 8 11:32:22 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Thu Feb 8 11:32:30 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
CloseCopy
Copyright © 2024 GL.iNet. All Rights Reserved
hansome
February 12, 2024, 8:59am
6
Will the same exported wireguard conf file work on your phone APP?
The wierguard server may become unreachable after system upgrade/reboot.
