I was successful connected to Wireguard server from my client with out fault, but after disconnecting (moving from place to place) and relocating a couple of times, my client is no longer connecting to the server successfully. I get ‘ the client is starting please wait’ but it won’t turn green and connect successfully. What could it be? My isp router is a static ipv4 and when I’ve looked at my server, I can see that it is running correctly with the green sign instead of amber. Any advice please
Please check:
- Is there a need for port forwarding from your ISPs router to your server?
- Does your ISP use CGNAT?
- Does your ISP block WireGuard ports?
Yes u had to port forward for my isp to server
Yes, I*
Also i was connected successfully while moving around for the last 4 months.
Yes ISP does allow portforwarding yo wireguard
So you need to double check if your port forwarding is correct - any maybe even change the port to avoid any blocks by your ISP. For example, some ISPs (like Spectrum) block UDP 51820 and 51821
So port forward again using a different port, What port do you suggest i use? Im not sure which ones i should or shouldnt open l. Pls and thanks
And should i set it up completely from scratch?
Please refer to How to get support quickly to provide more information about your device and setup in general.
