I am writing to seek your assistance regarding an ongoing issue I have been experiencing with my GL X3000 router for over a year. Despite multiple attempts to connect through WireGuard VPN, I have been unsuccessful, although I can connect without any issues via OpenVPN.
Upon conducting extensive research online, I have come across several articles and discussions suggesting that my problem may be related to time synchronisation. Currently, I am located in Amman, Jordan, where the correct time zone should be GMT +3. However, my router is displaying the time as GMT +2, which I believe is contributing to the connectivity issues with WireGuard.
Could you kindly provide guidance on how to update the NTP servers on my router to ensure that the time is correctly synchronised? Your expertise in this matter would be greatly appreciated, as I am eager to resolve this issue and utilise WireGuard effectively.
Thank you for your attention to this matter. I look forward to your prompt response.
Please see the attached screen shots as I have tried wireguard with different ports but none had a successful connection. I have also reset the router and left the ntp as is and didn’t sync yet I can connect OpenVPN but I can’t make a connection on wireguard.
Please I would really appreciate it if you could help me with this issue. I desperately need the wireguard connection.
Hence the reason it is the only one without domains.
I did noticed in a bit older versions this had issues, which makes sense because you cannot resolve domains in a tunnel which cannot be up because the domain cannot be resolved.
This was also a little misconception i had when vanilla openwrt 'leaked' dns over wan, its by design to resolve domain endpoints over wan, and then the origin change to vpn location.
But i do know this was a issue with gl firmware, last time i did not encountered it, but please check with direct vpn ip as endpoint.
Yes on my mobile I can connect through Wireguard with Windscribe and Proton no issues what so ever, but having the Wireguard profile on the router I have no chance to connect. It’s so weird
