I have tried to set up a connection between my Fritzbox 7530 as Wireguard server and the slate AX as client for a few days. I finally managed after a few adjustments to get a green light, connection established, however no internet coming through (50kb shown, nothing loading). All my testing done while LTE Tethering of my Slate AX.
The goal is to use the router abroad while appearing with my home IP address.
my settings:
Fritzbox: Wireguard connection to other router, IP of distant client set to 10.0.0.0/24 (initially I tried adding the IP of the Slate AX, but that did not work) / 255.255.255.0, Dynamic DNS created at a free provider.
Config Slate AX
[Interface]
Address = 10.0.0.1/24
ListenPort = 51820
PrivateKey = XXXXXX
DNS = 192.168.178.1
MTU = 1460 → I played around here between 1300-1500, nothing changed
[Peer]
AllowedIPs = 192.168.178.0/24
Endpoint = XXXDynDNS: 51789
PersistentKeepalive = 25
PublicKey = XXX
PresharedKey = XXXX
Some of my slate AX log below
Sat May 4 09:30:01 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Sat May 4 09:30:01 2024 daemon.notice netifd: Network device ‘wgclient’ link is up
Sat May 4 09:30:01 2024 daemon.notice netifd: Interface ‘wgclient’ is now up
Sat May 4 09:30:01 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sat May 4 09:30:04 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=3 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_2186 group_1504 group_4471 group_9712 peer_2001 group_3604 peer_2002 CONFIG_cfg030f15_ports=
I appreciate any support.
BR
