WireGuard connection to a TP-Link ER605 server
I am trying to setup my GL-AXT1800 as I travel to be able to coennect, using WireGuard, to my home network. At home I am using a TP-Ling ER605 that has WireGuard server. I have setup the ER605 WireGuard with:
MTU: 1420
Listen port: 51820
Private key: XXXXXXXXXXXXXXXXXXXXXXXXX
Public key: yyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
and the local IP address for the interface: 192.168.0.2
Then I setup the GL-AXT1800 Wireguard as follows:
[Interface]
Address = 192.168.0.2/24
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
DNS = 8.8.8.8, 8.8.4.4
MTU = 1420
[Peer]
AllowedIPs = 192.168.0.0/24
Endpoint = XXXXXXX.ddns.com:51820
PersistentKeepalive = 25
PublicKey = yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
Trying to start he VPN tunnel, it just sits on orange. Looking at the log I am getting this:
Wed Dec 11 23:19:57 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Wed Dec 11 23:20:50 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Wed Dec 11 23:20:55 2024 daemon.notice netifd: wgclient (17329): Try again: xxxxx.ddns.com:51820'. Trying again in 1.00 seconds... Wed Dec 11 23:21:01 2024 daemon.notice netifd: wgclient (17329): Try again: xxxxx.ddns.com:51820'. Trying again in 1.20 seconds...
xxxxx.ddns.com is my WAn connection IP adrress from my TP-Link ER605 at home which is registered with a dynamic DNS provider.
Any ideas will help.
thank you kindly,
Dorin
On other devices, like cellphones or PC, use the WireGuard App/Software to use this same profile as the AXT1800, is it available?
Does your VPN server router (TP) WAN have public IP address? (NOT CGNAT)
Are you using TP Omada firmware on your ER605 or Openwrt?
On the other devices I do not have VPN clients installed.
On the ER605 I have just the Omada firmware that comes with the router wich has the WireGuard server. And yes the ER605 has a WAN public address.
It comes with Omada firmware not Openwrt
Just asking, as ER605 v2 supports Openwrt:
https://openwrt.org/toh/tp-link/er605_v2
Omada Stock ER605 Firmware is based on Attitude Adjustment if you have a V1, or Barrier Breaker if you have a V2.
Mine is a V2
Yes supports it but I do not want to reflash it with Openwrt.....I was wondering if I get the tunnel to work with Omada version. By me all the settings look ok but I cannot get th etunnel to work. On the other hand the OpenVPN component works and I can establish a tunnel between the two.
I mean test the profile on others client, like cellphone/PC to verify if the VPN server works.
