I have a weird question about Wireguard, DDNS, and Goodcloud.
My current version of GL-AR750S-220 is 3.024 (just updated). I read DDNS - GL.iNet Docs
Scenario:
Home1 = Router → GL-AR750S-220 Wireguard SERVER, DDNS enabled (port forwarded), Goodcloud enable and I can see it online from goodcloud.xyz
Home2 = Router → GL-AR750S-220 Wireguard CLIENT, DDNS enabled (port forwarded), Goodcloud enable and I can see it online from goodcloud.xyz
I can access using http://XXXXXX.glddns.com without any issue (to both) so I want to establish VPN between them.
If “Enable VPN Policy” is ON at Home2, I cannot connect Wireguard to the server at Home1, so I turn “Enable VPN Policy” OFF. Then I can connect Wireguard but I got kicked out from my remote management, I have to go “locally” (192.168.8.1) turn again “Enable VPN Policy” ON and I gain remote access again, the problem is that I have no physical access to local to Home1 so often
Finally, when I have “Enable VPN Policy” ON Goodcloud shows GL-AR750S-220 OFF.
- How can I connect wireguard remotely without been kicked out?
- How can I have wireguard connected and Goodcloud showing GL-AR750S-220 ON?
Thanks for your time!
JUAN PABLO
