I setup wireguard mullvad in the admin panel. Everyday twice the connection stops and my devices are off the internet. Mullvad allows 5 devices and only one is setup (router).
I download the openvpn mullvad config and this issue never happens but openvpn is slower. Why is wireguard disconnecting and not reconnecting? How to debug it?
I used wireguard_watchdog in cron tasks but it doesn’t do anything.
mine is a gl-mt1300 4.3.7
By posting your log here
Make sure that the DNS resolver is working properly.
OK! which log to post here?
The wg watchdog script just resolves ddns to IP changes.
Do you have a persistent_keepalive
value in your confs? 25 s is considered to be a good value to start from.
root@slateax:~# wg show
interface: wgclient
public key: [redacted]=
private key: (hidden)
listening port: 46190
fwmark: 0x80000
peer: [redacted]=
endpoint: [redacted]:51820
allowed ips: 0.0.0.0/0
latest handshake: 53 seconds ago
transfer: 7.91 GiB received, 1.21 GiB sent
persistent keepalive: every 25 seconds
System log should be fine - maybe just the lines that fits to the time where the wg connection drops.
There’s going to be a lot of noise. A reboot & logread -e wireguard
& one or two mins after booting might help the signal… especially if the wg watchdog sh is in play.
This is the default config by glinet admin panel setup
[Interface]
Address =
PrivateKey =
DNS =
MTU = 1380
[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint =
PersistentKeepalive = 25
PublicKey =
Is that MTU approp. to Mullvad? @admon, what do you use there?
I’m using all the default settings. Set up Mullvad using the integrated “config downloader” within the router and all works flawless. So I would assume the issue is somewhere else.
Well something’s not building the wg conf. I don’t trust those blasted ‘helpers’; when the providers make unannounced changes to their end’s api, it all breaks down.
I do manual setup. @gartanuspi , if the ‘helper’ doesn’t setup Mullvad, grab a conf from them & upload it manually to the WG Client GUI.
For me, this does not make sense.
Because if the helper would not be able to build the config - how should the connection work at all?
The helper does not rebuild it, if you don’t press the button for it.
So if the conn stops it can’t be related to the helper itself.
I refreshed the config 2 day ago
WG is a stateless protocol though; if there’s no traffic, there’s no packets… hence the need for keepalive directive. I’m not even sure if we have a vaild wg conf in effect here.
@gartanuspi can you ssh into the device & post the output of
wg show
cat /etc/config/wireguard
after a fresh reboot & trying to connect to Mullvad again… even if it fails?
interface: wgclient
public key:
listening port: 58161
fwmark: 0x80000
peer:
endpoint:
allowed ips: 0.0.0.0/0, ::/0
latest handshake: 1 minute, 22 seconds ago
transfer: 120.97 KiB received, 58.88 KiB sent
What do you have in /etc/config/wireguard
for Mullvad? Does this GL helper set up WG endpoints differently than manual confs?
config proxy 'global'
option global_proxy '1'
config providers 'AzireVPN'
option auth_type '1'
option procedure '0'
option group_id '4861'
config providers 'Mullvad'
option auth_type '2'
option procedure '1'
option group_id '7828'
config providers 'FromApp'
option group_id '7147'
config groups 'group_4861'
option group_name 'AzireVPN'
option group_type '1'
config groups 'group_7828'
option group_name 'Mullvad'
option username '0000'
option address _address
option public_key key
option private_key pkey
config groups 'group_7147'
option group_name 'FromApp'
option group_type '3'
config peers peer_01
option name _name
option location _location
option address_v4 v4
option address_v6 v6
option dns '193.138.219.228'
option end_point end_point
option allowed_ips '0.0.0.0/0,::/0'
option persistent_keepalive '25'
option mtu '1380'
option local_access '0'
option masq '1'
config peers peer_02
option name _name
option mtu '1380'
option masq '1'
config peers peer_03
option name _name
option mtu '1380'
option masq '1'
config peers peer_04
option name _name
option mtu '1380'
option masq '1'
config peers peer_05
option name _name
option mtu '1380'
option masq '1'
config peers peer_06
option name _name
option mtu '1380'
option masq '1'
config peers peer_07
option name _name
option mtu '1380'
option masq '1'
config peers peer_08
option name _name
option mtu '1380'
option masq '1'
config peers peer_09
option name _name
option mtu '1380'
option masq '1'
config peers peer_10
option name _name
option mtu '1380'
option masq '1'
config peers peer_11
option name _name
option mtu '1380'
option masq '1'
config peers peer_12
option name _name
option mtu '1380'
option masq '1'
config peers peer_13
option name _name
option mtu '1380'
option masq '1'
config peers peer_14
option name _name
option mtu '1380'
option masq '1'
config peers peer_15
option name _name
option mtu '1380'
option masq '1'
Sat Jan 20 11:53:10 2024 kern.info kernel: [ 15.210587] wireguard: WireGuard 1.0.20220627 loaded. See www.wireguard.com for information.
Sat Jan 20 11:53:10 2024 kern.info kernel: [ 15.219133] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Sat Jan 20 11:54:41 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_4861 group_7828 group_7147 peer_01 peer_02 peer_03 peer_04 peer_05 peer_06 peer_07 peer_08 peer_09 peer_10 peer_11 peer_12 peer_13 peer_14 peer_15 CONFIG_cfg030f15_ports=
Sorry; I should have mentioned: it can take the better part of a minute for the router to build the WG tunnel. Pls repost logread -e wireguard
in, oh, say, 2 minutes.
what does tunnell mean? I’m already using that connection, this is me from the router with wireguard, to post this message. log is the same now
The connection via WireGuard from the GL device → Mullvad is an encrypted data tunnel.
Does IP Leak show the expected Mullvad server location?
