i need to configure some DNAT and SNAT Rules for my wireguard VPN.
I saw that
- wg0 the vpn server is missing in the interfaces within luci
- the wireguard firewall zone has in its config files a device soecified (wg0) - but this is not visible within luci?
Can I simply create the missing wg0 interface (what i see via ssh with ip a on the router) under luci or will this break my vpn?
I‘ve also seen that my interface LAN has no interface specified in the config (the file contains a whitespace). Does rules within this Zone/Interface are working? Do you know where I can find the default content of /etc/config/firewall wirhout the need to reset the device?
Thank you
Matthias
