Wireguard Issue (continuous disconnections) ( GL-MT3000 )
Hi all, I'm experiencing constant connection reboots; I'm using wireguard and controld.
I can't figure out why.
FW -> latest stable
I'm attaching the crash log
Sun May 11 15:52:35 2025 daemon.notice netifd: Network device 'wgclient' link is up
Sun May 11 15:52:35 2025 daemon.notice netifd: Interface 'wgclient' is now up
Sun May 11 15:52:35 2025 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Hideme IPVanish Mullvad NordVPN PIA Surfshark FromApp group_180 group_3147 group_2465 group_5432 group_8399 group_7717 group_684 group_3651 group_8221 peer_2003 CONFIG_cfg030f15_ports=
Sun May 11 15:52:35 2025 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun May 11 16:24:20 2025 daemon.notice netifd: Network device 'wgclient' link is down
Sun May 11 16:24:20 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sun May 11 16:24:20 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun May 11 16:24:20 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun May 11 16:24:21 2025 daemon.notice netifd: wgclient (2263): RTNETLINK answers: Permission denied
Sun May 11 16:24:37 2025 daemon.notice netifd: Network device 'wgclient' link is up
Sun May 11 16:24:37 2025 daemon.notice netifd: Interface 'wgclient' is now up
Sun May 11 16:24:37 2025 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Hideme IPVanish Mullvad NordVPN PIA Surfshark FromApp group_180 group_3147 group_2465 group_5432 group_8399 group_7717 group_684 group_3651 group_8221 peer_2003 CONFIG_cfg030f15_ports=
Sun May 11 16:24:37 2025 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
The reason for the VPN disconnects did not find from this log.
Is the connected VPN server self-built or a third-party VPN provider?
When the router VPN client drops, please disable the VPN client, and check the Internet is normal?
Please share whole issue syslog with us.
It crashed without VPN; I uploaded all the logs on the device
nginx.tar (235 KB)
logreadkernel.tar (235 KB)
logread.tar (235 KB)
From the syslog you attached, we found the MT3000 WireGuard client is not disconnected, but the MT3000 detects the radar channel, and triggers the DFS scan, repeater is disconnected and own WiFi is silent during the scan, which causes the wireless client to disconnect.
  1. Is there any WiFi disconnect issue during use of ASUS router when the WiFi bandwidth at 160MHz?
  2. Please try changing the bandwidth of the primary WiFi (ASUS) to 80MHz and select fixed CH36 to reduce the impact from the radar.
