I noticed that every once in a while, one of my WireGuard configs will stop working even though on other devices, the same config with the same keys will work on the same network, so it’s not the upstream. I also notice that as soon as I create new keys for the WireGuard interface, it seems to start working fine again. A lot of the times it seems to connect but then it disconnects again and provides no internet, but as soon as I install new keys, it seems to work fine. Other configs will also continue working fine.
It seems to happen especially when I switch from using tethering (stop the router) and then move to Ethernet or repeater setting.
Anyone else going through this? I’d be happy to provide logs.
I got something smilliar aswell, if I go back to repeater mode and then back to wan cable it seems also to be happening.
I do have nextdns active, and wireguard but I cannot use internet even if I try to restart wireguard via the dashboard it won’t connect only when I fully restart the router it fixes it.
