from my Provider, i get some wireguard configuration.
Since some days one wireguard configuration is no more working.
How can i see the wireguard logs ?
In the System log i can found nothing,
about wireguard.
Thanks a lot
about wireguard.
Thanks a lot
Unfortunately there is no log for wireguard.
Does the wireguard server have any logs?
My router is showing inbound connections to the Lan from my GL-Inet MT-300A running WireGuard server:
[LAN access from remote] from 183.136.225.12 port 59418 to 192.168.39.10 port 500 Wednesday, Jun 09,2021 00:24:28
[LAN access from remote] from 205.185.114.54 port 47427 to 192.168.39.10 port 500 Monday, Jun 07,2021 04:34:08
That is the access log we added, not the connection error log of wireguard.
Sorry - those log entries above are from my upstream router.
MT-300A is a client on that network, with port 500 opened for Wireguard server. Is there away to see the connection history on the MT-300A
Currently there is no connection history of wireguard server. You can only see online connections.
