I am using the GL-MV1000 router. When I try to complete the wiregraud manual vpn client configuration I got the popup message Caution:Note that only data accessing subnet 0.0.0.0/0 will pass through the VPN.
I am wondering, do i need to worry about this message? I am able connect to my work station with the GL-MV1000 router. my concern is only this message. can anyone pls comment on this?
If you are only using a VPN to connect to your private network, you can ignore this message.
This message is for those who use a VPN to access the Internet for privacy protection.
Thanks’ for the reply. I will be using the Router VPN to connect my work station so that I can work from different country. I am wondering since i am getting above popup message will it cause any issues?
