Wireguard Menu Order
Regarding the menu "VPN > Wireguard Client":
  1. Is it possible to somehow remove the pre-configured providers (Mullvad > Surfshark) by editing a file, for example?
    OR
  2. Can you add the option to either remove / hide them
    OR
  3. Can you add the option to re-order, so that MY servers (eg. Amazon VPS, Oracle, Deep Ocean etc.) are shown first / above them?
Thanks in advance,
Happi
So, I edited (ie. stripped out all the unwanted, pre-installed providers) /etc/config/wireguard and it worked great...but does not survive a reboot.
If it's that important to you, you could add a little script to rc.local to do this on every reboot.
