Hi all,
I’ve created on an Vos an wireguard server. I can connect without problems in my android.
When I try to import the config file I get all ways that the port is incorrect.
If I configure manually I can stablish connection but I lose internet on all my Lan devices.
Any help?
If you try to ping the WireGuard server’s internal IP address, can it access?
Hi Again,
afer better looking for the android settings i’ve saw that the ip came on the config file and i’ve change it.
after fixing that my wireguard vnn client is working at 4mb per second.
do you have idea if the vpn connectio avoid the ISP traffic shaping for streaming?
