Hi, My wireguard profile stopped working. When I checked the configuration file, I found that the endpoint was a numerical IP address, and did not reference the *.glddns.com dynamic ddns name. This means it works until my IP address changes.
The profile comes from an AR750S and looks like this:(numbers altered!)
[Interface]
Address = 10.001.001.5/32
ListenPort = 14299
PrivateKey = =
DNS = 64.6.64.6
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = 109.157.120.118:51820
PersistentKeepalive = 25
PublicKey = nu979n99ALhSQQClKi4QgbmAif0Q1Xb7plmIsl5wRbiXLsUU=
The Endpoint is the problem! My IP address changes regularly it should look like:
Endpoint = oc5d999.glddns.com:51820 then it would not stop working when my IP changes.
Although it might need a restart on the client.
Both text and QR code profiles are affected.
I have tried to edit the profile on the client, an Android phone, but the change does not seem to be saved in the profile. I have done this successfully for other clients - my linux laptop for example.
Can someone confirm this please?
