I wonder if someone can help me with my problem with wireguard on a GL-AR750. I upgraded to the latest firmware version and even tried the pre-release version (gl-ar750-mesh-0912.bin).
I want to start the wireguard server via the GUI, but pressing the start button simply has no effect.
I connected via ssh to the router and only trying to stop the service triggers some “response” -see below
Anyone got a clue what’s going wrong?
Ulrich
root@GL-AR750:~# /etc/init.d/wireguard start
root@GL-AR750:~# wg show
root@GL-AR750:~# /etc/init.d/wireguard stop
uci: Entry not found
- Clearing IPv4 filter table
- Clearing IPv4 nat table
- Clearing IPv4 mangle table
- Clearing IPv4 raw table
- Populating IPv4 filter table
- Rule ‘Allow-DHCP-Renew’
- Rule ‘Allow-Ping’
- Rule ‘Allow-IGMP’
- Rule ‘Allow-IPSec-ESP’
- Rule ‘Allow-ISAKMP’
- Rule ‘guestzone_DHCP’
- Rule ‘guestzone_DNS’
- Forward ‘lan’ → ‘wan’
- Forward ‘guestzone’ → ‘wan’
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘guestzone’
- Populating IPv4 nat table
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘guestzone’
- Populating IPv4 mangle table
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘guestzone’
- Populating IPv4 raw table
- Zone ‘lan’
- Using automatic conntrack helper attachment
- Zone ‘wan’
- Zone ‘guestzone’
- Zone ‘lan’
- Clearing IPv6 filter table
- Clearing IPv6 mangle table
- Populating IPv6 filter table
- Rule ‘Allow-DHCPv6’
- Rule ‘Allow-MLD’
- Rule ‘Allow-ICMPv6-Input’
- Rule ‘Allow-ICMPv6-Forward’
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘guestzone’
- Populating IPv6 mangle table
- Zone ‘lan’
- Zone ‘wan’
- Zone ‘guestzone’
- Set tcp_ecn to off
- Set tcp_syncookies to on
- Set tcp_window_scaling to on
- Running script ‘/etc/firewall.user’
iptables: No chain/target/match by that name.
ipset v7.3: The set with the given name does not exist - Running script ‘/usr/bin/glfw.sh’
/etc/rc.common: .: line 5: can’t open ‘/lib/mwan3/mwan3.sh’: No such file or directory
! Failed with exit code 2 - Running script ‘/usr/sbin/glqos.sh’
