Wireguard on AR300M
I just setup a Wireguard server at home and am able to use Wireguard from my Android cellphones to it using the Android wireguard client. All attempts to use Wireguard client on my AR300M have failed so far with no handshakes ever received by my server from the AR300M.
Is anyone using Wireguard client on AR300M with the latest firmware and did you have to do anything special to get it to work?
Thanks!
Could you please share your export wireguard client configs, maybe a qrcode, with your key and ip masked. You can modify and generate with QR code generator.
I’m having a similar issue with the wireguard client… please let us know if you figure it out
I just did a reflash and it fixed my issue
Just wanted to post an update that when I upgraded to the latest FW it just worked.
