I put together some documentation, commands, and script for getting wireguard running at boot. It can be started/stopped/etc. from the terminal as well.
It handles support for multiple wgX.conf interfaces automatically.
Thanks for your share
I would like to see this functionality incorporated into the official firmware ![]()
With a persistent folder for Wireguard *.conf files that survives updates/upgrades would be a huge win. It would allow us to safely update the firmware remotely without losing access.
This feature has been involved in our future firmware released plan, please kindly wait!
Or it would be great if you added a wireguard client to the webui like tailscale
I just allowed an upgrade from 1.4.1 to 1.4.2, and my wireguard configuration was preserved. Did this previously not work, or does it depend on major/minor firmware upgrades?
Since I have updated my KVM to V1.5.0 release1 wireguard does not connect on boot .Could you update the script please ?
I wonder if the remote access work?
I have upgraded KVM at my home so it is not problem and tried reinstall wireguard but the main problem is that is not start after reboot. But it connects but when I restart kvm it does not automatically connects to wireguard server. Where should I put S99wireguard start script ?
Sorry it was windows formated somehow and I had to convert it linux formated style with dos2unix S99wireguard
This one should be on the Knowledge Base really. Ideally, made easier through the UI too.
