My setup is as follows:
Site A with GL inet router connecting to site B VPN server. Kill switch enabled, everything goes through VPN tunnel.
Also on site A I have a laptop hard wired to the GL inet router and the laptop is connecting to site C with VPN.
What type of VPN should I use between site A and B so the nosy people at site C can't tell that I am at site A and not site B?
thanks
WireGuard is usually the best choice.
Is there any was on site C the packets can be inspected and discover that there is a WireGuard VPN tunnel between A and B? or the VPN server strips out that information before passing the data on?
In your specific case network C won't know about VPN.
But I don't understand how you will access from site B…
