Does anyone know of a way to set the WireGuard server to use port 53. When I try to save the configuration the GUI says that I have selected an invalid port. Thanks
Have you already disabled dnsmasq and any other DNS servers?
If i remember correctly you are not allowed to use ports lower than 1000. Try setting a higher port ![]()
Thanks. I was hoping to use port 53 to get around a strict firewall. Thanks
Try setting the port via config files and see if it works?
Why?
This doesn’t seem very smart - 53/UDP is DNS, and this can fall back to TCP for records that are too long.
GUI is right - it’s an invalid port.
Look at ports 80/443 instead.
