Hi there,
I tried to find some solutions on existing posts here and on google related to my issue, but I couldn’t find one.
I have setup a WireGuard server on a dedicated Ubuntu 18.04 server on which I want to connect from my GL.iNet AR750 with latest snapshot for this device from GL.iNet.
When I click connect, the gray spot next to WireGuard in the UI becomes yellow after some time and remains this way. I can ping and ssh my machines in my lan, but I cannot ping anything on the internet. I’ve tried to set 8.8.8.8
onto the DNS field, disabling VPN policies, … with no luck.
After quite some time, the yellow spot remains but:
VPN client failed to connect, this may be because wrong configuration, unsupported parameters or terminated by the server
Here is the server configuration (enp0s20
is my public interface name on my Ubuntu server):
[Interface]
Address = 10.0.0.1/24
SaveConfig = true
PostUp = iptables -A FORWARD -i %i -j ACCEPT; iptables -t nat -A POSTROUTING -o enp0s20 -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -t nat -D POSTROUTING -o enp0s20 -j MASQUERADE
ListenPort = 51820
PrivateKey = xxx
[Peer]
PublicKey = xxx
AllowedIPs = 10.0.0.2/32
And here is the configuration on my GL.iNet router:
On the WireGuard server side, here is what I get with wg show
interface: wg0
public key: xxx
private key: (hidden)
listening port: 51820
peer: xxx
endpoint: my-glinet-router-public-ip:5740
allowed ips: 10.0.0.2/32
latest handshake: 53 seconds ago
transfer: 79.94 KiB received, 3.36 KiB sent
and here is what I get on my GL.iNet router for the same command:
interface: wg0
public key: xxx
listening port: 5740
peer: xxx
endpoint: my-ubuntu-server-public-ip:51820
allowed ips: 0.0.0.0/0
transfer: 92 B received, 340 B sent
persistent keepalive: every 25 seconds
I’d be pleased if anyone could help me, or at least tell me in which direction I should drive my investigations. I’m far from being an expert in networking…
Thanks in advance
