when you run wireguard VPN server(i.e home-vpn network) on the gli.inet router (i.e router#1 )
the devices connect to router#1’s wifi, are they considered to be on home-vpn network or does each device need to connect as wireguard client separately?
If not, I’m trying to run my own wireguard vpn server on router#1 and want all devices connect to router#1 to be also be on the same vpn network. what setup I need to do. thanks in advance.
