admon
August 27, 2024, 12:46pm
21
A router works differently than a Pi, due to network seperation. Normaly you want to seperate networks, which is an essential security feature.
I can only tag @bruce to forward your question because I don't use this setup.
Bruce: Is it possible to show VPN clients in AGH instead of localhost?
@bruce would you kindly give a feedback regarding how to make VPN ip's visible as hostnames in AdGuardHome.
AGH handles clients is activated...
Thanks a lot.
Neuro
bruce
August 28, 2024, 8:24am
23
Here for your reference:
Since firmware 4.6 has implemented independent configuration of VPN DNS (i.e., Allow Custom DNS to Override VPN DNS), we redirect the DNS query through VPN into a separate process and put AdGuardhome as upstream of it. This is a safer mechanism: the VPN dnsmasq process runs when VPN connection is established and exits when disconnected.
When "AdGuard Home Handle Client Requests" is turned on, the "AdGuard Home will show DNS query logs by client" function is affected in the following modes:
G…
That is a complex issue, VPN is handed all DNS traffic, and the ADG client list is affected, but this is for the best security for the VPN tunnel to process DNS. This known issue in the develop plan, kindly await.
Thank you for your quick response!!
Neuro
