I’m connected from my laptop, the connection works and it shows on the router’s WireGuard Server section as you can see on the screenshot above.
The problem is that I’m not able to access the Internet. First time I set this up it was all working perfectly, but I think (I’m not 100% sure) that it stopped working after I did this: Access devices behind GL-SFT1200 (Opal) from different local subnet - #15 by lobo
I have seem a few posts in the forums having similar problems (not able to access the Internet) and I have tried a couple of things, like changing the DNS or changing the IP Address from 10.0.0.1 to something like 10.1.0.1, but no luck.
Also, I’ve noticed that, when connected to the OPAL router (without VPN), and I can access Internet with no issues, I’m able to ping the main router (192.168.1.1), but when I’m connected through the VPN I’m not even able to ping the main router, so it may be something regarding the Firewall - Zone Settings? I have no idea, here is how mine looks at the moment:
When testing, I connect to the server from my laptop (connected to my mobile phone network). Connection works fine (so the main router has the port forward done correctly if I’m able to connect properly, right?)
That screenshot where the WireGuard Server client list shows the 192.168.8.138 IP Address may be from one of the tests I did, probably still connected to the Opal router on my local network.
But for you to see what exactly shows when I’m connected to my mobile phone network and I connect to the VPN:
I had it disabled, which is what I needed to do in order to be able to access devices behind the Opal router from my main net.
Now, it seems like enabling it again fixes the VPN no internet issue, but I’m not at the router location at the moment so I can’t confirm if by enabling the Masquerading again “breaks” what I achieved in the other post.
