I have a flatrate 5G mobile SIM and currently I use it at home as the router by activating the Android hotspot to connect my laptops to the internet.
At home I have two routers GL-inet B1300 and TP-WR902AC with OpenWRT.
I connected the B1300 to my Android hotspot and my devices at home can connect to the B1300 wifi and have the internet access. With this setup I created a local LAN with the IP 192.168.8.X, which differs to my Android hotspot (e.g. 192.168.100.X). So far so good, and I don’t need to use my second WR902AC router.
Now, I would like to use the wireguard VPN. What is the appropriate setup for my situation since my B1300 isn’t connected to an internet provider and assigned to a public IP address?
My first trial today has failed. I’ve just set up the wireguard server on B1300, copy the configuration on my Ubuntu 22 laptop to /etc/wireguard/wg-b1300.conf , and start the wireguard client with wg-quick. Afterward my laptop doesn’T have access to internet.
Is it possible to setup a Wireguard server with my setting? If yes how?
With the GL-B1300 behind the Android hotspot, you need port forwarding from the Android device to the WireGuard server on the router. Android does not have port forwarding built-in, but there may be apps that can be installed to do that.
I suggest you can look into using AstroRelay.
I created an AstroRelay account and a link for the WireGuard Server. Then, I connect to my router wifi, changed the endpoint in the wg configuration file under /etc/wireguard/. If I activate the wireguard client on my laptop, I can’t connect to internet. As a test, I can access the dashboard of my router from another link agent that I created.
How can I troubleshoot this issue?
Update: It seems to work now. My question is now, using such a setting, I won’t see any different of my public IP, isn’t it? I get the same IP either with enabled or disabled wireguard client.
