I want to replace a simple RaspberryPi setup running Wireguard Server on my home network using GLiNet AR300M, (and not using as a router), when connected it allows an external (and internal, really whatever client connects to wireguard) connections to reach the home network lan, and then also reach the internet via forward.
The main primary home router is a plain ordinary router, not GLiNet or any type VPN setup there.
Port Forward (home router), to GLiNet AR300M with Wireguard Server all working
Using bridge mode, as a client the GLiNet AR300M is able to obtain DHCP from the home router, I’m able to SSH and ping local network as well as reach the internet on the AR300M itself.
From the internet I’m able to connect to the GLiNet AR300M Wireguard Server (still running despite not being shown in the device admin pages). I can successfully connect, start a session, exchange keys, forward all traffic and ping the AR300M itself.
However, the zone, firewall, and routes are not set to forward traffic, thus I’m not able to reach other devices on the home network and not able to reach the home router for internet, probably just how bridge mode is configured, with wan / lan / vpn / accept / forward / reject rules, not set to forward traffic in this manner, and need to be adjusted for this. As again, using SSH I can log into the device and reach the local network and internet, but Wireguard traffic is not set to foward (stock settings)
Much like the RaspberryPi, as a client on the network, it’s just a matter of configuration, I’ve got the luci interface enabled, SSH to config files, but have not yet been able to add the right settings.
The usual WG server approach adds ‘PostUp’ setting:
PostUp = iptables -A FORWARD -i wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE;
I’ve looked at the zone/firewall, and allowed traffic, but still missing something. Running OpenWRT, and not much different setup than the RaspberryPi, this should work.
Posting this, as other may know which specific config entries or firewall settings to adjust, thanks.
