The wireguard docs are broken on the site: https://docs.gl-inet.com/en/3/tutorials/wireguard/
Setting up a manually config for wireguard, what do I put into “Endpoint Host”? When I use the IP of the server it says it is invalid.
URL changed. Better not change. But you can use the URL now.
You need to input endpoint
ip_address:port
Ok how do I generate the key pairs for the client details running on my router?
If you want to configure manually, you should refer to Wireguard website.
To generate the keys, pls refer to Quick Start - WireGuard
You can generate the key pair anywhere, not necessary on the router.
