Hello... I have Mango GL-MT300N-V2 and know ethernet speed is only 100 Mbps and max Wireguard 45 Mbps, but with WireGuard VPN get only 20/20 Mbps speed (for example same VPN in other Tplink router give me 200/100). Is that the limit for Mango or I didn't set something right. Thank you.
"...Tests conducted on a local network. Real world speeds may differ depending on your network configuration..."
That's the reason ![]()
Expect the half of the announced speeds.
Well, it's a Mango with 1cpu core and very limited RAM. Hardware limitations are a big factor here. I bet the TP has slightly better specs.
How are you testing? Make sure you're using ethernet on both the WAN and LAN side.
My GL-AR750 Creta is rated at 50 Mbps on the GL-iNet website but I'm only averaging around 35 Mbps. On the other hand, my GL-X3000 Spitz AX is rated at 300 Mbps and that's what I get.
Yeah, i use WAN/LAN...
