Wireguard stoped working after some minutes.
I set up my wireguard server and client, all was working for some minutes at the beginning,
I was able to check my IP showed usa while I’m in DR.
So it stoped working suddenly after some minutes, can someone help?
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): Warning: fw3_ipt_rule_append(): Can’t find match ‘connmark’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Zone ‘lan’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Zone ‘wan’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Zone ‘guest’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Zone ‘wgclient’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Set tcp_ecn to off
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Set tcp_syncookies to on
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Set tcp_window_scaling to on
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Running script ‘/etc/firewall.nat6’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Running script ‘/var/etc/gls2s.include’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): ! Skipping due to path error: No such file or directory
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): * Running script ‘/usr/bin/gl_block.sh’
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): Failed to parse json data: unexpected character
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): uci: Entry not found
Fri Apr 5 02:32:44 2024 daemon.notice netifd: wgclient (17182): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Fri Apr 5 02:32:44 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Apr 5 02:32:44 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Apr 5 02:32:44 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
how did you fix this issues?
