Wireguard suddenly not connecting
Hi there, i have a slate plus that i use as a travel router to connect to a slate ax that is connected to my AT&T modem. I have been connecting successfully The past year until yesterday. Now the wireguard is no longer connecting with my router at home. This is the message log I get in the vpn log. Would appreciate any help!
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Rule 'out_conn_mark_restore'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Zone 'lan'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Zone 'wan'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Zone 'guest'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Zone 'wgclient'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Set tcp_ecn to off
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Set tcp_syncookies to on
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Set tcp_window_scaling to on
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Running script '/etc/firewall.nat6'
Mon Dec 8 07:11:23 2025 daemon.notice netifd: wgclient (31827): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): * Running script '/etc/firewall.vpn_server_policy.sh'
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): * Running script '/var/etc/gls2s.include'
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): ! Skipping due to path error: No such file or directory
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): * Running script '/usr/bin/gl_block.sh'
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): uci: Entry not found
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (31827): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Mon Dec 8 07:11:24 2025 daemon.notice netifd: Interface 'wgclient' is now down
Mon Dec 8 07:11:24 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (32077): Name does not resolve: `el765ef.glddns.com:51820'
Mon Dec 8 07:11:24 2025 daemon.notice netifd: wgclient (32077): Configuration parsing error
The log message indicates a DNS resolution issue:
Please try manually specifying a DNS server to see if that resolves the problem.
