Wireguard van to specified domain list
Hello, I have a strange VPN issue. It was working before, but after I had to reset my Flint2 device, I haven’t been able to configure it again.
I successfully set up my Mullvad VPN account on the router. In fact, if I create a policy like “from all devices” to “all destinations,” it works without any problems.
However, what I want to do is enable the VPN service only for “all devices” to “specific domain addresses.” When one of the domains on the list is accessed, the VPN should activate; in all other cases, traffic should continue without VPN. The rule I created is below, but I can’t get it to work at all.
What could be the reason for this? I tried turning the “kill switch” off and on, and I also toggled the “All Other Traffic – Allow Non-VPN Traffic” option at the bottom on and off, but it still didn’t work. Am I missing something, or could this be a software issue? The version I’m using appears to be 4.8.3.
Thank you in advance for your support.
Please ensure:
  1. The encrypted DNS feature is disabled on client devices
  2. The client device is using Flint 2's LAN IP address as its DNS server (typically 192.168.8.1) or has “Override DNS Settings of All Clients” enabled in Admin Panel > Network > DNS
  3. If using AdGuard Home, disable “AdGuard Home Handle Client Requests” in Admin Panel > Application > AdGuard Home
Thank you for your support. After changing adguard settings it works fine.
