Hello can you help me make (step by step guide) working configuration of Wireguard Vpn in Luci?
Router is Ax1800 Flint FW:4.3.2
I have Warp conf with:
[Interface]
PrivateKey = %PrivateKey%=
Address = 172.16.0.2/32, fd01:5ca1:ab1e:8c9c:813d:ce61:fe5d:4bb2/128
DNS = 1.1.1.1
[Peer]
PublicKey = %PublicKey%=
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = 162.159.193.5:2408
i try to put it manually but vpn don’t work. Can you help me step by step what i need to config?
I install this package:
p.s Why you need this luci vpn? On main Glinet Gui vpn work just fine with no issues.
yes it’s work, but with standard WG vpn in glinet gui i have issues with smb so i want to try different way with luci vpn may be its work with no issues with smb.
