Hello, I have an issue with the app. I added some VPN wireguard profiles using the iOS app. when I disconnect from the VPN, the profiles disappears and I have to do it add them from scratch
so I reset my router. same issue. I add a wireguard profile, I connect. when I disconnect it disappears.
The profile should stay in the app.
You can only push the current using one to the router. When you push a new one, it replaces the old on on the router.
Maybe not optimal, but this is how it is designed.
I have the router and app for 1.5?years!
the profiles never disappeared!
I am using iphone app v 1.0.16(60), just tried XE300 3.211 firmware.
Tried openvpn and wireguard and I don’t have this problem.
Have you tried uninstalling, then reinstalling the app on your iPhone?
Developer confirmed that its a bug of the iOS app
