WireGuard VPN Setup with NAT IP
Hi Team,
I am currently running a WireGuard VPN Server on my GL-MT2500 and need some advice regarding client configuration generation.
Here is my current network environment and setup:
  • Device Setup: The GL-MT2500 is connected behind my primary router.
  • ISP Constraints: I do not have a static IP, and my ISP does not allow direct port forwarding on my router. Instead, they allocated a specific external IP address (which is different from my actual public IP) and a specific external port (let's use 1234 as an example).
  • Routing: To make this work, I created a NAT rule on my main router that allows external access by forwarding traffic from that ISP-provided port to the WireGuard listening port on the GL-MT2500.
The Issue / Current Workaround: The VPN connection works perfectly with this network setup. However, when I generate and download a client configuration file from the GL-MT2500, it automatically populates the Endpoint value with my standard public IP and default WireGuard port (which won't route correctly).
Currently, my workaround is to open the downloaded config file in a text editor and manually change the Endpoint field to match the ISP-provided IP and port before saving it to my client devices.
What I need support on:
  1. Endpoint Override: Is there a way to globally override the default IP and Port in the device settings (or via LuCI) so that newly generated client configs automatically use the ISP-provided details?
  2. Setup Optimization: Given my network constraints, do you have any other recommendations, alternative approaches, or best practices for running this WireGuard setup?
Thank you for your feedback.
We’re planning to improve the VPN server configuration in a future v4.9.x release, which will allow users to customize the server address directly in the GL UI to simplify the process in this scenario.
At the moment, there isn’t another way to achieve this. Please continue manually modifying the exported configuration file for now.
