I am using a Velica GL-B2200.
When using wireguard my internet speed averages on 200/50. (Both wired & wireless).
My normal speed is 1000/50. (Our provider doesn’t provide higher upload speeds).
Is there a way to increase the internet speed while using wireguard, or is the current speed to be expected?
Thanks for your time in advance
You are at the maximum Wireguard Speed that the processor will allow. To get more throughtput you would need to us a GL-AX1800 Flint that has a maximum throughput of 120mbps OpenVPN and 600mbps Wireguard.
Hi, thank you very much!
I’ll be returning the B2200 and getting the AX1800
Just be aware that Flint Runs on Choas Calmer 15.05.1, a old openwrt build that Gl-iNet has packages for (Upgrade is coming soon to openwrt21) Is not MeSH compatible and does not have a Bluetooth module.
I am aware of the OpenWRT version yup, atm Velica GL-B2200 runs the same, so that’s not an issue for me.
I also will just place it in front of our Deco mesh system, so as long as it does provide 1GB/s with cable it’s really all good
Thanks for the suggestion, I need to do better research before purchasing next time
