I setup manual Wireguard. It connects quickly via WAN cable link.
However, when I disconnect the cable and tethers the router to a wifi spot, Wireguard will not connect.
It reported REKEY-TIMEOUT error in the logs only when tethering to another wifi.
Strange.
Not sure about the reason as I didn’t met this problem.
Is this your own wireguard or a commercial wireguard service?
Its my own Wireguard server.
So can you private message a working config so that I can try?
I do have the same issue on the new Slate AX, described below
@alzhao if you find a solution, please do also let me/us here know
Thanks a lot
Yes I noticed that thread.
