Hi, for some reason, if I configure the DDNS on the AXT1800 client, it does not connect to the WireGuard server. If you ping the DDNS it can resolve the same IP address, I also tried with other DDNS I use in the server workplace and is the same result.
I can connect with my phone WireGuard client with no problem using the DDNS.
Below you can see the log, first I connected configuring the server IP address, later I turn off, configure the DDNS of the server (that works on the WireGuard from my phone and was working before this update), and it stays on that loop.
This is a know bug of this version?
Please let me know if any more information is needed to check this out.
Sun May 18 10:53:10 2025 daemon.notice netifd: Interface 'wgclient' is now up
Sun May 18 10:53:10 2025 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_3002 group_2320 group_5287 group_3505 peer_5449 peer_7183 peer_6891 peer_1366 PIA Surfshark NordVPN Hideme IPVanish group_6495 group_9462 group_8780 group_1747 group_4714 peer_2005 peer_7896 CONFIG_cfg030f15_ports=
Sun May 18 10:53:10 2025 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun May 18 10:54:30 2025 daemon.notice netifd: Network device 'wgclient' link is down
Sun May 18 10:54:30 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sun May 18 10:54:31 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun May 18 10:54:40 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun May 18 10:54:40 2025 user.notice root: disable GRO on wgclient
Sun May 18 10:54:45 2025 daemon.notice netifd: wgclient (14791): Try again:ksxxxxx.glddns.com:51820'. Trying again in 1.00 seconds... Sun May 18 10:54:51 2025 daemon.notice netifd: wgclient (14791): Try again:ksxxxxx.glddns.com:51820'. Trying again in 1.20 seconds...
Sun May 18 10:54:57 2025 daemon.notice netifd: wgclient (14791): Try again:ksxxxxx.glddns.com:51820'. Trying again in 1.44 seconds... Sun May 18 10:55:04 2025 daemon.notice netifd: wgclient (14791): Try again:ksxxxxx.glddns.com:51820'. Trying again in 1.73 seconds...
Sun May 18 10:55:05 2025 daemon.notice netifd: Interface 'wgclient' is now down
