My wireguard works perfectly on my ar750s but it won’t let me set port 53 anyone know how to Force it to use port 53? Thanks for the help.
If that’s not possible how do I set it up with open VPN…
Port 53 is reserved for DNS. You should not be using any ports lower than 1000, linux actually does not let you bind to ports less than 1000 without root.
Thanks I wanted to use it to get around captive portals with openvpn.
That port is always open I have done it with DNS tunnling before
