I am using my GL-AXT1800 with the Surfshark OpenVPN client.
I configured it to use a static IP.
The current router setting is "Network Provider Router" ---(ethernet)---"Slate Router"---(ethernet)---"Personal devcices".
The vpn works well when I connect a laptop with a ethernet cable.
However, when I connect my phone via wifi to the slate router, the phone doesn't seem to go through the vpn. For example, when I check my current location while connecting to the Slate's wifi, it shows an actual location not the vpn server location.
Is there an additional setting that I have to configure to enable the vpn for the WLAN?
Your laptop (cable) and your wifi devices (wireless connectivity) under the AXT-1800, they are same in the LAN, so please check your wireless device if are they connected to the AXT1800 wifi?
For 1, I am not sure how I can check it, but I guess they are. When I am checking the connected clients, both LAN and WLAN devices are having the identical numbers for the first three parts. e.g "NNN.NNN.N.133" for LAN device and "NNN.NNN.N.166".
For 2, the current VPN policy is set to "Global Proxy" saying all trafic goes through VPN.
Ok, I somehow got the reason. It was because of the iCloud Private Relay function setting the location depending on the system's time zone. So it was not a router's problem! Still, thanks for the support and hope this thread could help someone in the future..
