For which it doesn’t work at all… just me?
Which router model are you using?
It does not connect to open WiFi or not stable?
M300N-V2
It says ‘success’ on connected to the open network but in fact has not connected and returns me to the admin config page and the WiFi isn’t connected… I’ve seen this on more than one open network, works fine with a network with a password
Will try openwrt route…
Who is the provider of the open network?
I just tried my Mango with firmware 3.201 and it can connect to open network. It just takes several tries to get IP address so I waited 10+ seconds
That is interesting, the wifi network is in a private holiday home and is being used extensively by many devices. My version is also 3.201, maybe i did not wait long enough for an IP address, i will try again. However, i was pretty sure i had the same issue with another open network a while ago… Thanks for testing it for me
just checked again and it did the same thing. finds the network when i scan… says ‘success’ when i try and join and then returns me back to the main page but the repeater mode is not activated and it does not think it’s connected. are there any logs which i can view on this device…
You can ssh to the router and use logread
to get the log.
not a lot in the logs, looks like it reboots…
Tue Jun 29 08:44:10 2021 user.info : saved ssid ignore: Treworgey 0
Tue Jun 29 08:44:10 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=Treworgey, encryption=none, bssid=18:E8:29:67:F4:D9, wds=0, device=mt7628, identity=, channel=11
Tue Jun 29 08:44:10 2021 user.notice apcli: apcli0 down
Tue Jun 29 08:44:10 2021 daemon.notice netifd: wwan (19907): udhcpc: received SIGTERM
Tue Jun 29 08:44:10 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Tue Jun 29 08:44:10 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Jun 29 08:44:11 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Tue Jun 29 08:44:11 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Jun 29 08:44:11 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Tue Jun 29 08:44:11 2021 user.info : [ 2895] gl-wifi-core>> bIsStaEnabled=1
Tue Jun 29 08:44:16 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=11
Tue Jun 29 08:44:16 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Jun 29 08:44:16 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jun 29 08:44:17 2021 daemon.notice netifd: wwan (23848): udhcpc: started, v1.30.1
Tue Jun 29 08:44:17 2021 daemon.notice netifd: wwan (23848): udhcpc: sending discover
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Jun 29 08:44:17 2021 daemon.notice netifd: wwan (23848): udhcpc: read error: Network is down, reopening socket
Tue Jun 29 08:44:17 2021 user.notice apcli: apcli0 down
Tue Jun 29 08:44:17 2021 daemon.notice netifd: wwan (23848): udhcpc: received SIGTERM
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Jun 29 08:44:17 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jun 29 08:44:18 2021 daemon.info dnsmasq-dhcp[2287]: DHCPREQUEST(br-lan) 192.168.8.163 dc:a9:04:72:15:33
Tue Jun 29 08:44:18 2021 daemon.info dnsmasq-dhcp[2287]: DHCPACK(br-lan) 192.168.8.163 dc:a9:04:72:15:33 Liams-MBP
Tue Jun 29 08:44:18 2021 daemon.notice netifd: wwan (23930): udhcpc: started, v1.30.1
Tue Jun 29 08:44:19 2021 daemon.notice netifd: Network device ‘ra0’ link is down
Tue Jun 29 08:44:19 2021 daemon.notice netifd: wwan (23930): udhcpc: sending discover
Tue Jun 29 08:44:19 2021 daemon.notice netifd: wwan (23930): udhcpc: sendto: Network is down
Tue Jun 29 08:44:19 2021 daemon.notice netifd: wwan (23930): udhcpc: read error: Network is down, reopening socket
Tue Jun 29 08:44:26 2021 daemon.notice netifd: Network device ‘ra0’ link is up
Tue Jun 29 08:44:26 2021 daemon.notice netifd: wwan (23930): udhcpc: sending discover
Tue Jun 29 08:44:26 2021 daemon.notice netifd: wwan (23930): udhcpc: sendto: Network is down
Tue Jun 29 08:44:26 2021 daemon.notice netifd: wwan (23930): udhcpc: read error: Network is down, reopening socket
Tue Jun 29 08:44:29 2021 daemon.notice netifd: wwan (23930): udhcpc: sending discover
Tue Jun 29 08:44:29 2021 daemon.notice netifd: wwan (23930): udhcpc: sendto: Network is down
Tue Jun 29 08:44:29 2021 daemon.notice netifd: wwan (23930): udhcpc: read error: Network is down, reopening socket
Tue Jun 29 08:44:29 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Tue Jun 29 08:44:29 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Network device ‘apcli0’ link is down
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Jun 29 08:44:33 2021 daemon.notice netifd: wwan (23930): udhcpc: read error: Network is down, reopening socket
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Network device ‘apcli0’ link is up
Tue Jun 29 08:44:33 2021 user.notice apcli: apcli0 down
Tue Jun 29 08:44:33 2021 daemon.notice netifd: wwan (23930): udhcpc: received SIGTERM
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Jun 29 08:44:33 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jun 29 08:44:33 2021 daemon.notice netifd: wwan (24285): udhcpc: started, v1.30.1
Tue Jun 29 08:44:33 2021 daemon.notice netifd: wwan (24285): udhcpc: sending discover
Tue Jun 29 08:44:36 2021 daemon.notice netifd: wwan (24285): udhcpc: sending discover
Tue Jun 29 08:44:39 2021 daemon.notice netifd: wwan (24285): udhcpc: sending discover
Tue Jun 29 08:44:48 2021 daemon.info dnsmasq-dhcp[2287]: DHCPREQUEST(br-lan) 192.168.8.163 dc:a9:04:72:15:33
Tue Jun 29 08:44:48 2021 daemon.info dnsmasq-dhcp[2287]: DHCPACK(br-lan) 192.168.8.163 dc:a9:04:72:15:33 Liams-MBP
Tue Jun 29 08:45:17 2021 user.info : Function:main Line:30 auto repeater switch not be opened
