I have just flashed a copy of openwrt 19.07 to my GL-USB150 router. I replaced wpad-basic with wpad-openssl and found that I could set the wireless security to wpa3-sae.
I successfully connected my laptop running Windows 10 1909 and got internet access. I am very pleased with this.
I usually run ubuntu on the laptop, but this I couldn’t get it to connect. I suspect the DKMS driver for the rtl8821CE wireless chip because it wouldn’t connect when PMF (protected management frames) was switched on in the router.
The GL-USB150 uses the Ath9k driver for the Qualcomm QCA9331.
WPA3 supporting HMW and NGW wifi cards are available on ebay from intel an fevi for lower than 20USD
WPA3 are supportet by p.e. by follow router by pre release firmware:
FRITZ!Box 7590, 7490** (04 March 2020)
FRITZ!Box 7530** (06 March 2020)
FRITZ!Box 6591 Cable** (7 February 2020)
FRITZ!Box 6590 Cable, 6490 Cable** (21 February 2020)
FRITZ!Repeater 3000, 2400, 1200, 1750E** (04 March 2020)
Source: FRITZ! Lab | AVM International
Intel wifi cards with WPA3 support:
Intel® Wi-Fi 6 AX201 dont buy, need special sorts of intel cpu
Intel® Wi-Fi 6 AX200 buy, can used with all cpu
Intel® Wireless-AC 9560, old
Intel® Wireless-AC 9462, old
Intel® Wireless-AC 9461, old
Intel® Wireless-AC 9260, old
IOS 13 - any device capable of running IOS 13, can support WPA3
MacOS 10.15 - any Mac with WiFi 5 (802.11ac) supports WPA3, older Macs that support 802.11n do not
I tried repeating this experiment and the results showed me that openwrt does not seem to set up wpa3 without switching off the wireless. When I tried rebooting the USB150 router, to reset the wireless, openwrt reverted to wpa2, so I am afraid the outcome was not what I thought. The same happened with PMF (protected management frames) . I searched the specification of the QCA9331 and there was no mention of PMF or 802.11w (the same thing). So, it does not look as if the USB150 will be able to cope with wpa3.
The 19.07 release brings initial support for WPA3. However, WPA3 is not enabled by default and requires installing specific packages: to run WPA3 as an access point, hostapd-openssl is needed. For use as a Wi-Fi station, you need either wpa-supplicant-openssl (station support only) or wpad-openssl (AP + station). Due to their large size, these packages are not installed by default, and it is impossible to install them on devices with less than 8MB flash.
It should also be noted that many existing client devices will never support WPA3, and that there are client devices that support WPA2 but cannot connect to an AP configured with WPA2+WPA3 mixed mode. Please only file bugs if you are sure the problem is not client related.
To configure your device as a WPA3 access point, see wpa_modes
I did install wpad-openssl but I think it was due to the hardware not supporting 802.11w (Protected Management Frames). The Openwrt silently returned to wpa2 on reboot, and did not use the new wpa3, leading me astray. I now doubt if this device (USB150) will ever be able to support wpa3.
Here is a link that explains a bit about PMF or MFP or 802.11w for those who may be a bit confused.
(Caution: it is a bit complicated…)
