wrong country code on FLINT2 - IT>DE
Hi everyone,
I'm experiencing the same issue mentioned in this thread: MT6000 - wrong hardware country code
I live in Italy and purchased my Flint 2 from Amazon Italy. However, when I check the country code, I get:
cat /proc/gl-hw-info/country_code
DE
Is this a potential problem? Can it be resolved with the help of GL.iNet support?
Thanks!
Please rest assured to use it. The entire European region uses the DE hardware country code, which has no impact on the use of the router and there will be no potential issues.
Of course, if you need to modify the WiFi country code, you can make adjustments in the Luci page.
In the luci interface Netwok-> Wireless then edit the intefaces. In the middle of the displayed page the country can be choosed.
yes, I changed the Wi-Fi country code right after unboxing the router :wink:.
Thanks.
