X-3000 very slow wifi
Had the unit for close to a year now and only started using the wifi a few days ago. Noticing some strange behavior. When connected to the wifi on the X-3000 I can get LAN data fast close to 700mbps however the upload is dismal. It will peak out real fast on some devices to about 10mbps then drop to .4 or so. Some other devices it will stumble hard for about 3 sec or so and then ramp up to 100mbps or so.
Steps taken so far: Good cables, Tried multiple devices all with issues, ethernet plugged into the X-3000 works as it should, other AP's in the house all work on wifi as expected, Tried 2g and 5g no change as well as different channels and bandwidths all the same result, cell data seems to go through just fine it's only when transferring over the LAN that the issue shows. Internal LAN testing has been with Open SpeedTest Server. Again everything works as it should until I am connected to the X-3000 wifi. Running the beta from a few weeks ago not the new one.
Any more steps or logs I should look at to try to get this figured out?
Thanks.
About the UL speed, WLAN/LAN -> WAN is normal, and the WLAN/LAN -> WLAN/LAN (means br-lan) is not normal?
What the X3000 firmware version is? v4.8.0 Beta 2025-04-24?
If downgrade the firmware to v4.7.4, will it normal?
